No, rears definitely will not fit.
Inside Clearance at the strut is also problematic.
With my setup I clear the strut by 5mm
You might find that the rear is hard to control with that spring setup on this short wheel base.
The general rule of thumb is about 100 differential f/r., unless you adopt a full rear CO. Then springs are pretty much an even setup.
Yeah, I used to run -2.0 rear camber & have edged it up to max grip.
I have a feeling I'll settle in about -2.2 after play time this year
