Originally Posted by Varinn
Yup had them mounted for a while now, decided to do a winter wheel swap despite the temps outside.
18x8.5 et35 w/ 245/40-ZR18 Michelin PSS @ -1.50° camber, minor rub full left lock
18x10 et25 w/ 275/35-ZR18 Michelin PSS @ -1.00° camber, zero rubbing. Planning to return to stock camber soon, drives great in straight lines but I think stock would be better for hard corners when summer comes.
What is stock camber value? More negative camber will give you better cornering grip
Where are you rubbing up front? Inside or outside? If you're rubbing the outside then going back to less negative camber will make it worse.
FWIW, I have 18x9 ET37 with wide-running 245/40/18 tires up front and I don't rub at all even during hard cornering at autocross. I added $5 camber washers so my camber is at -2.7*
