Help! might have fried my radio (UPDATED)
Hey all,
I could use some help.
I was trying to install the OEM ipod adapter kit into my car. For some reason it wouldn't work. I decided to back out and figure it out. However when I reconnected everything as it was and removed the ipod harness my radio won't even turn on now.
Does anyone have a wiring diagram for the wiring harness? from any year or radio model, just somewhere to start from?
I can confirm it has both +12vdc permanent and switched +12vdc at the proper connections and the ground is intact. Outside of that I'm lost. The radio was not installed at any sensitive point so it is extremely unlikely the head unit is fried.
is there a control module for the radio that I can scan? I have NCS expert and INPA and any software needed.
any help would be appreciated.
thanks
