BAM! 26 pounds off. Stock battery is 41.5lbs, the Deka EXT20L is 15.5lbs. Started the car, works fine. used the stock bottom plastic piece because there is no carpet under it, drilled 2 holes for the mounting thing's sticks, and it holds perfectly. Just gotta clean up and detail that area so it looks cleaner. Car starts fine. Also have a battery tender, but I don't think I'll need it since I use the car daily. Will see.
More trunk space too. look at the size compared to stock. I can fit 3 of them inside the stock one.
