Originally Posted by RedDotRacer
Maybe switching to an 18 inch wheel will help with better tire fitment? How do you like the square setup vs staggered? Either way a 202.xxx is moving!
Oh, my bad. I just realized I posted 19x9.5 rims all around by mistake. I was actually running 18x9.5's all around with 235/40/18 F and 265/35/18 R.
My intention of running the square wheels was to fit a wider set of front tires, but that idea went down the toilet when I realized my lower spring perches are in the way. The wider front rims did provide a bit more grip and response to the 235's as they slightly stretch out the side walls to provide a more stable contact patch.
Now I just need to find myself some shorter front springs to move my spring perch up in order to accommodate some wider front tires.
