Originally Posted by mcaden
My Z4 MC came with a spare set of VMR Wheels (VB3/V703) with a square set up of 18 x 8.5 (ET 40) and tire size 255/35 R18. Would it be helpful run a spacer in the rear, if so what size? I happen to have a pair of 15 mm spacers with longer lug bolts, would that be appropriate?
The prior owner ran the rears without a spacer, but someone said they didn't look flush.
Thanks for your input!
Marc
Offset calculator says you're 16 mm retracted relative to stock setup. So a 15 mm spacer will get you closer to the stock look as far as flushness to fender.
When I was running stock setup I had a 10 mm spacer (ride height lowered 25 mm) with no issues so I think you could do a 25 mm spacer and be fine and get an even more flush look. Of course you would have to make adjustments to the front to get a consistent look front to rear.
