Originally Posted by pungo
I wasn't aware there is was any electronics/sensors on the shifter/trans except the reverse light switch.
Are you saying, with the EWS module coded to not require the clutch to be pressed to start the car and the shifter is in any gear, the starter won't engage? I assume the ignition/spark/fuel pump would still be active so you can jump the car in gear rolling down a hill?
Thanks for the reminder I meant to confirm this sooner.
The car was on the lift ramps at the time, so I didn't confirm the 'in gear' lockout.
I posted what the code description was and only checked neutral start.
I had the car out last night, and you are correct, there is no in gear detection.
The car will start clutch out and in gear.
I have amended my post .
