Originally Posted by ///S54
Thanks!
I can just remove the stock silencers from the X portion and it will end up to be the same setup as the 545.00 option right?
Were it that easy.
I'm pretty sure it's all welded as one piece.
You could maybe take a sawzall to it.
There are threads on here where peeps have taken a sawzall to the stock mufflers, pulled all the guts out, and welded the cover back together.
Keep an eye on the classified section and you may see a used x-pipe come up for sale.
If you want to make a racket on a budget, here you go:
http://www.zpost.com/forums/showthread.php?t=1102873
