Originally Posted by papak
I ended up going with 12mm front and rear. I am running BFG Comp T/A 2s all around on stock alloys. The clearance is perfect but if I had lowered the car, I would probably have limited myself to 10mm spacers, particularly on the front.
For anyone considering spacers, be careful about going with 10mm size, particularly if the provider claims they are hubcentric type. The BMW hub that centers the wheel can protrude as much as 11mm preventing the spacer from sitting flush against the hub. More info is available on the
TMS site.
