Hi,
thank you for the informations. The binary hacks would be a bit too much, i think.
In the last days i read about coding the DSC ECU on E46 M3's. Very interesting. Maybe i will read more about it and look what is available on the older DSC.
Due to the button behaviour: I think an easy fix is to put some electronics between the DSC push button and the ECU. I've already measured it and a simple logic in a micro controller would do the work. I will give it a try the next days.
Daniel
