Originally Posted by Piper1
I'm on eibach/koni combo on my non M and do rub a little (apex ec7 et31 18x9 toyo r1r 255/35/18), not as much as you see in this thread but in a slightly different location at full lock. M vs non M sit different in caster due least in part by the offset on the LCAB. Even stock height with camber plates with the M more aggressive caster on 255 I'd be surprised if you didn't rub least a touch.
That's a bummer to hear. My goal was to run a square setup.
Looks like it's back to the drawing board.
