Thread
2JZ in a Z4 Coupe - Custom Project
08-14-2016, 10:24 AM
30
dre99gsx
Drives: 1994 Toyota Supra
Replacing automatic brake pedal with manual brake and clutch
Clutch uses the same brake master cyl reservoir
Tried to find a way to convert to a drive-by-cable pedal system, but there is no room for one under there. Even tried to fit a E30 and E36 gas pedal to no avail. I'll end up controlling the Z4 3.0si DBW throttlebody with my standalone.
Powered up the 2JZ ecu to test the DBW Aristo throttle body using the Z4 pedal. Voltage ranges of the Z4 pedal don't match the ranges expected by the 2J ecu, thus it won't work.
New 2J oil cooler seals
Cleaned the oil cooler of the ugly gooky mess from supposed overdue oil changes from this motor
ARP head stud washers - older kits used smaller diameter washers which would dig into the 2J head. This kit has the correct washers. Black = ARP Gray = OEM 2J
Was planning on using the oem 2J intake manifold - not only is the Z4 throttle body larger in diameter, but this would awkward custom mounting
Headgasket, seals, parts
More child labor. I keep finding kids on the street to help turn a bolt
2J VVTi crank pulley - 36 - 2
Andre -
2J into a Z4 Coupe!
01:13 PM
Quote
dre99gsx
View Public Profile
Find More Posts by dre99gsx
