If you buy one for 10k be prepared to drop in at least 2.0 to 2.5K in maintenace catch up unless you do the work yourself and you will save a bundle. Springs may be cracked, wheel bearings may need replacement, and with the m52 and m54s the cooling system may need an overhaul. Not to mention at that time you probably want to be ready to do all the fluids, plugs, and filters. If you go ahead and buy them keep ecs tuning and bmwpartssources in mind.
Regards and good luck with the purchase.
- Chris
