After talking to APEX, I have two options for a square setup (with stock struts and no lowering):
1) 18" x 9.5" ET35 with 265/35 tires. Will also need camber plates with about -2.5 degrees camber. Additional 12mm spacers are needed to push the back tires out for aesthetic purposes.
2) 18" x 9" ET42 with 245/40 tires. Additional 20mm spacers are needed to push the back tires out for aesthetic purposes.
Option 2 doesn't really put any more rubber on the road verses stock tires (225/45 front and 255/40 rear), and less than what I have today (245/40 front and 275/35 rear). So, it looks like I'll be investing in a set of camber plates.
