Originally Posted by ga41
Thank you for your reply drbvac. Is there not an option for using the exact same wheel all around? Instead of different offsets front and back? Say for example 18x9 30 offset on all corners?
I recommend 9.5 +35 square on 255/35/18. Rear will need atleast a 10mm spacer to make it flush. I recommend running -2 up front for clearance. A 5mm spacer may also be needed to clear front strut body (some say it clears without it, but its a little too close of a clearance for me).
Here are some pics for reference to my setup.
