Sure. I just had a regular 4 wheel alignment because I just went from a 17" square setup to an 18" staggered setup with a different offset and tire size in the rear. Passenger side rear tire had one tread barely off the ground. Driver's side had all treads evenly on the ground. 72k miles on the chassis. It's a 10 year old car (Sept 2002 production). I figure the rubber bushings are starting to go. I've already had to change the FCA's, FCAB's, and FSM's because the rubber in those parts had deteriorated pretty badly.
Stock bushings are good for about 50,000 miles before they begin to deteriate, depending on roads and conditions. You are probably due.
