$500 shipped to lower 48. Will not split pod and gauges at this time.
Included in the sale:
- 3D Design gauge pod. This pod is no longer made. $362 new
http://www.zpost.com/forums/showthread.php?t=548722
- SpeedHut boost gauge with VF Engineering logo. Boost sensor included.
- Speedhut AFR gauge. Calibrated for AEM wideband, sensor not included (this is how it comes from SpeedHut).
- SpeedHut oil temp gauge. Temperature sensor included.
Gauges are black faced with white lettering, light up red at night, and have silver bezels. Used but good condition.
What you will need:
- AEM AFR sensor (SpeedHut sells the gauge only, without a sensor).
- Adapter if you want to pull oil temp from the oil drain plug.
- I lost the small black plastic piece that goes under the button on the boost gauge for peak recall. It's cylindrical in shape, about 1 cm long and a few mm in diameter. You can get a new one from SpeedHut. I can't imagine it costing more than a few cents plus markup.
I'm selling for a couple of reasons. First, I've deviated well beyond the VF stage 1 kit. The car is high boost and reliant on methanol injection, which has required me to switch setups to include a failsafe. Secondly, I never got around to installing it. Too many projects, not enough time.
I have more than $800 invested in this setup, plus labor to fit the gauges (see photos). I'm not looking to split at this time. A buyer could sell the gauges on one of the many other forums (E46/E9x M3) and keep the pod if so inclined.
Thanks for looking!
