Originally Posted by ZStig
Anyone know if a larger diameter pulley on the air con will hurt it? Maybe shorten its life?
This was the original question.
Originally Posted by pokeybritches
http://www.engineeringtoolbox.com/pu...ds-d_1620.html
I would think the danger is in overspeeding the compressor. Figure out the max speed of the compressor off a spec sheet, and then use the formula to calculate the max speed it would see based on 8000 rpm and the pulley diameters.
And here was the answer.
