Originally Posted by NickyC
Hi there. I've searched a bit, but can't find much on my particular situation. I'm currently running 19x8.5 +30, 19x10 +22 with 245/35/19 and 275/30/19 tires, along with H&R coilovers on my Z4M. I'd like to keep the front tires the same size, but would really like to get a 285 or maybe even a 295 in the rear. Do you think a 285 or 295 sized tire, say 285/30/19 would be an ok fit in the rear with a 19x10 +22 wheel? As it stands right now with my current setup, the car is pretty low and I haven't had a single rub ever.
Please keep in mind this car is for the street, and I'm not interested in how fast it can go around some orange cones, that I'm messing up the balance, or that I have less of a contact patch now or something. I just like the look of a fat rear tire, and appreciate any feedback you might have regarding if a wider tire will fit or not with no other modifications. Thanks a lot.
How much are you lowered approximately on those H&R coilovers? I have the same front wheel spec as you and was curious how the 245/35 tire fits with your ride height. Also which brand tire are you running?
