Originally Posted by apexhittinbull
2)I bought the S54 Cam Alignment tool kit which comes with TDC crankshaft lock pin, And I read that these need to be cut to fit on our E85/6 cars due to lack of space? Is this true, shall I go to the machine shop to cut the pin 2/3 of way?
It does need to be shorter. Here is the actual part used on our cars.
https://www.ecstuning.com/b-genuine-...n/83300495528/
Check out this thread for how short it should be if you're cutting yours.
http://www.zpost.com/forums/showthread.php?t=1112938
Good links and pics here, as well. The M3 DIY has lots of photos and step by steps.
http://www.zpost.com/forums/showthread.php?t=1048461
Salty
