Originally Posted by dc_wright
Originally Posted by GuidoK
SMG might be mechanically easier, as that is dimentionally the same as the 6spd manual. (but you obviously need the gear selector mechanism)
But I dont know about the electrical consequences. It might be tied into the ecu etc. generating fault codes when the smg is missing.
Finding someone that can competently reflash the ECU from auto (or SMG) to manual is the biggest challenge in this swap on an E36, E46, or E85.
I did not know that this was an issue. On the next generation DMEs, there is only a single calibration file for all three transmissions. So an msv70 N52 can swap transmissions without any difficulty.
