IMO, the ideal sizes and offsets for this car are:
19x10 +25 (a range of +23 to about +27 would work well and keep it flush)
19x8.5 +32 (a range of about +30 to +35 would work well and keep it flush)
I have the 19x10 +25/19x8.5 +32 conbo on my car and it is about as flush as possible and does not stick out or rub.
If you want to run 19x10.5 in the rear, you will want an offset of about +30 ideally to have it remain flush with the fender. +25 will definitely stick out slightly.
If you want to run a 19x9 in the front, then you will want an offset of about +39 to about +41 for a flush fitment.
