I bought an older laptop with real serial port and cable with ADS interface. If EDIABAS have ADS interface support it should work. The problem with this bundle setup is it is not a full version so it does not have ADS support. Look in C:\EDIABAS folder hardware folder is missing. It should be simple to switch between OBD and EDIABAS by changing EDIABAS.INI from interface = ADS. I have it setup to use ADS/ODB.
As I recall, it said E36 support. That is probably true but have limited access via OBD. I'm not knocking the seller. He instantly offer me a refund. It's just an FYI for those thinking this have ADS support.
