Could I get some opinions on these rim/tire combos? My main concerns are if I would have rubbing issues, if the tires would look stretched, and if they would stick out past the fender. Also, I can't decide between the 18" or 19". I like the look of the 19", but I'm worried it will crack/bend on Oklahoma's mediocre roads. Is there significantly more risk of damage between the 18" and 19"?
I have a '03 3.0i with the sport/perf package and factory suspension. Using
http://www.rimsntires.com/specs.jsp, I came up with these set ups:
Apex ARC-8
Front:
Tire - 225/40R18
Wheel - 18x8.5 ET38
Difference - 9mm (.4")
Rear:
Tire - 255/35R18
Wheel - 18x9.0 ET42
Difference - 8mm (.3")
VMR V718
Front:
Tire - 225/35R19
Wheel - 19x8.5 ET45 CB72.6 5x120
Difference - 2mm (.1")
Rear:
Tire - 255/30R19
Wheel - 19x9.5 ET45 CB72.6 5x120
Difference - 5mm (.2")
Thanks!
