Originally Posted by Rated M Roadster
A spike is caused by a rev during shifting or hitting the limiter; it's not intentional. lol
I don't see how this helps your problem...
Yeah well in general spiking over what the tune was meant for could be dangerous yeah? Hence why I brought up the safety issue. But like I said, if AFRs are still good up past 9psi then who cares, it's all good!
As for the recording, it would help because then I could see whether or not my car is the only one with the idle issues. Can you do a short recording for me? With light throttle taps and let-off? I want to see if your idle behaves the same as mine, where it dips and comes back up. It tries to steady itself, but is not smooth at all.
I don't particularly care about my power delivery nor output right now, since I'm banking on those to be up to par after I do a charger core swap. VF said they would send one to me with a core charge, since they found that my unit is out of date and uses a different impeller; and is most likely the culprit of my lower output.
