Originally Posted by 3002 tii
Thanks! I went with another solution though. I am swapping in a screen and the motor from an E83. Not sure why nobody else mentioned this as these units are plentiful and cost way less. You obviously need to swap everything into the old shroud/surround and the mounting brackets for the newer motor are slightly different.
The only issue I am running into is that the gear on the motor has a crack. This little gear is prone to failure and the guy that did the retrofit in the link you posted didn't check his unfortunately. I'm now trying to source a replacement gear.
