I just installed a set I bought from a member. One thing that I needed to buy was 4 metric nuts for locations B and C. On mine the bolts screwed directly into the OEM cans but on the Diablos they passed through and required nuts. Not sure your will be the same but just a heads up.
Good luck with the install and your be pleased when you turn it over for the first time.
Regards
