      03-22-2015, 01:01 PM   #348
DanFromTucson
Drives: Z4 M Coupe
I'm looking for some installation help.
I just started (finally) installing my mounts. I'm also installing the Motorsport 10.9 bolts and nord-locks at the same time. My question is around torque specs. Specifically, I'm trying to confirm which bolts need 21 NM of torque and which need 59 NM + 90 degrees of angle torque?
I suspected it would be the single bolt that goes into the rubber mount which requires 21 NM, and the 4 new Motorsport bolts which connect the bracket to the engine block would require 59 NM + angle torque.
When I uninstalled the old bits though, I'm finding that the bracket-to-block bolts on the driver side were fairly loose while the top motor mount bolt took some effort.
A quick confirmation would be much appreciated!
