Originally Posted by AlamosZ
So I know what the official #'s are but since BMW tends to underate their cars' hp and #'s, what are real life 0-60 or quarter mile times for the M-Z4 and Z4 Mcoupe??
The Z4 3.0si Coupé is quite close to the advertised 5.7s at around little over 5.6s (To differentiate it from the 130i with the same engine at same power rating: N54B30 @ 195kW/315Nm and 45kg (100lbs) more weight, the 130i is advertised as being 6.1s 0-100, but in actuality it will do it at 5.63s stock.) - both also have same gearboxes, same gear ratios and same final drive ratio.
The Z4 M Coupé does closer to about 4.5-4.7s in real life. I test drove it last fall against a E39 M5 that was advertised at 5.4s 0-100 in it's time, and the Z4 left the M5 almost like a stick in shit... but then at 140km/h the M5 started catching up, due to it's 500Nm V8... But the early race was very decisively Z4MC's.
Best regards,
Jussi
