aux input
I tried the install the EZ way via the under dash blind,etc. I am unable to connect harness back into radio with confidence blind,,since radio no work anymore.I'm thinking maybe it's not seated properly. Or I did something to make the radio think it was being stolen so now it's dead.. <How do i wake it up if that's the case?> so i tried the remove vent technique to be sure the harness is well seated. Getting the prongs to release from the vent has been tough since they don't protrude at all. So stymied again!:sad0147:
The extra 12 pin connector that i referred to in an earlier post with 2 brown wires..apparently this may be the wiring for Sirrius sat antenna. ??? Is that maybe correct? Since i'm not using Sat radio i should be able to swap that 12 pin for the new one, i think..
BTW if i did something wrong power wise is there a link to resetting radio to work?
thanks
