Originally Posted by DanFromTucson
I just installed some Bilstein B6 shocks in the rear of my Z4MC as part of my 55,000 mile suspension refresh. The Bilsteins didn't come with bumpstops or dust covers, so I assume I'm supposed to reuse the assembly from my old shocks.
The diagram in the box shows an external bump stop, so that seems to support my theory.
Can someone confirm?
You're supposed to buy new bump stops (item 4) and new mounts (item 6) to go with your new shocks. You can reuse the dust covers if they're not damaged or haven't become embrittled with age. The Rogue Engineering mounts are a better choice than the OEM, but at a minimum you should replace the OEM.
http://bmwfans.info/parts-catalog/E8...ing_and_parts/
