okay so the debate over nitrogen is a loosing debate the simple fact of things is that the air is majority nitrogen, valve stems wear, temperatures change causing the seals to contract and change size loosing air pressure, really in the end you are wasting your money to have to check your air pressure 1 less time per month.
