More progress!
No idea where the hell its coming from!
Its not the windscreen, we are able to replicate the leak by spraying below it and the window seal doesnt even get wet. The door hinge doesnt seem to be it either, rather it comes through near it but trickling over it doesnt cause it either. Somewhere behind it maybe... A spot weld on a bracket possibly?
The stud that is barely visible right at the rear corner of the hood in my last picture is roughly the area we suspect. In all honesty we are thinking that the only way to find it is to pull the fender and check the brackets behind. I'm unsure if I have the means to do that at my home garage, running out of space as it is.
