      07-01-2010, 07:40 AM   #55
crfine88
crfine88's Avatar
442
Drives: E86M
Originally Posted by doozyj View Post
I love the TE37s! What are the correct offsets for the Z4M without having the roll or pull the fenders?
Car looks awesome, totally bad ass!
Thanks for the compliment.
It will depend on the suspension set up you run.
With the H&R springs I ran the following with very minor rub on the plastic liner to the rear fenders:
Front 19X8.5 et 40 w/ 245/35/19 tires
Rear 19x10 et 25 w/ 275/30/19 tires
The rubbing in the rear would only happen when the suspension was under full compression in tight turns at high speed.
The front offsets I am running now are good as long as you have camber plates, and use at least -2.5 degrees. Without the more aggressive camber adjustment these fronts will rub. With the camber adjustment, there is no rubbing at all.
Current front set-up: 19x8.5 et 30 w/ 245/35/19 tires.
