Originally Posted by Beedub
The car is heavier than i expected though :-( 1430ish KG!!!! mine with the hardtop must be 1500kg.....
its a little bit heavier, I thought I'd be near 3150lbs, but then again I have a fully loaded interior with navigation and extended leather. Without 6 gallons of gasoline, I'd be at 3114lbs.
My rears saved me some weight in the rear, but the overall wheel/tire package up front is much wider and bigger than stock, and I think heavier
I was fortunate enough that there's a FREE and very accurate scale at this track. Byron, you really need to go weigh your car, and not at a truck stop that has a large error margin
