thanks guys for the vote of confidence. It was a ton of work, but well worth it.
I learned a lot going through the process. The first and most important is as you said, less is more regarding the amount of product to use. I barely buttered the pad with the carnuna...and it was still too much the first time around.
If anyone decides to use the klasse sealent and want's to do so by hand, make sure to use a foam applicator and not a microfiber. I think the articulations from the mf is what caused the light streaking.
