Originally Posted by unluky
Wow, if that is with no spacers at all, 20 mm might be too much. If you look at the "before" of mine up above, you will see that mine were under the car more to start with.
Good way to judge would be to put a straight edge from top to bottom on the tire/wheel (whatever it rests on) and then measure from the back edge out to see where 20mm would be. That is .80 inches, so it is more than you think. Measure first as many can not be returned after they are installed.
nice, i will do that first to be sure, thanks mate!
