Yes- I think the 20mm would fit easily. I measured before I ordered and the 20mm would still keep the tire under the lip in the rear. I think 20mm would be great, but since I did not like the 15's on the front and I own them now, I just did not see the point in still getting the 20mm for .19685" more outward move. Luckily the 20mm were on back order for another week, so I got the chance to cancel them.
I got the Turner spacers as recommended to me on here along with the longer bolts they recommended. Warning - the ones they sent me lightly touched the brake shield on the back side once I mounted them and spun the wheel. Probably an easy mod, but make sure and check when you install before you drop and roll. They fit fine on the back and clear everything. Spacers seem to be nice quality and customer service was top notch. I would recommend Samantha Marasca if you do not already have a rep there - very responsive and helpful.
I am happy with them so far for sure.
