      09-19-2013, 04:28 PM   #2
beta
Drives: 2006 M Roadster
Far from an expert, but here's what I'd recommend:
Originally Posted by drbvac View Post
IF I was to put APEX arc-8 wheels on that are
18 x 8.5 ofst 38 on the front
18 x 9.5 ofst 35 rear
Rear offset should be much lower, aka ET 22 if you don't want to run spacers.
Front 235/35 -18 or for that matter 245/35 - 18
rear 285/30 - 18
For 8.5/9.5 wheels I'd recommend 245/275. 285 will likely give you less grip and performance than 275.
Here's a thread with some beautiful 255/275 on arc-8.
http://www.zpost.com/forums/showthread.php?t=865009
I'd still recommend 245/275 just because it's about the largest you can fit with zero rubbing under any circumstance. And it's an ideal size for the rim width so you get the full contact patch. Finnegan in testing showed that having a smaller rim than the tire (even if the tire fits) gives you less performance than having the right rim width for the tire.
