Originally Posted by v3.0si
yes. the ///m-sport suspension is, if you believe BMW, 15mm lower than the non-sport suspension cars.
235/40 front and 265/35 rear will yield no rubbing.
you will still have fender gap, albeit 1/2" less than non-sport suspension. my car is a very similar look (fit-wise) to the VMR 18's... http://www.zpost.com/forums/showthread.php?t=515290
...and you can see how some angles make the car look tall, even with the ///m-sport susp.
thanks!
how about on a car without Sport package? Do you think the same set of CSL reps in 18 inch size and staggered would be okay? (I have two very good friends who have each just recently - and quite independent of each other - picked up really nice 3.0si's.
Cheers!
