Got it. Stay close to 26" Diameter or things will go awry with the instrumentation, roll-out, DTC, ABS, etc. To get it flushed, I'll need to drop it somehow. Either with lowering springs or shocks and springs.
If I get new 18" rims but keep the same tires or if I switch from the run flats, I need to keep the same size that I am currently running and everything should be good to go.
I just checked out the Adv.1 website and they've got some nice rims. But they are closer to $4500 a set. :-( If I spend that kind of money on rims, that's just less money on other things I may need to get. Will have to think about this one. Since I bought the maintenance program, I really can't mess around with suspension or the brakes.
Thanks for all the help, guys!
@Roffle Waffle,
Looks like you've got a set of 19" with low profile tires? It looks pretty sweet!
@Cal,
Thanks! The Montego Blue Z4 doesn't look bad with those rims. Something I will need to strongly consider.
@v3.0si,
I did call the guy who sold me the car and alignment will not be covered. :-(
