Originally Posted by Aries326
Ok, so what I gather is even with 19" wheels, I'll have a big fender gap even I don't use low profile tires. Either way, I really need to lower the car to get it to look flush. If I go with 18" with a lip, the rim will look smaller because of the lip so I should go with 19".
If I go with 19" and regular profile tires, what's the chance of it rubbing as I've seen other people complain has happened to them? Or did their's rub because their car was lowered too much?
Now going back to the alignment issue. Typically, how much are alignments at a BM dealership? Are alignments covered by the maintenance program I purchased?
Cal@SonicMS,
Those VMRs on the Montego Blue Z4M Roadster look pretty darn good. The car isn't dropped, is it? It doesn't look like it when compared to the white coupe. Those look really flush.
The Montego Blue Z4M roadster is running on 18 inch VMR VB3 and I believe it's stock suspension.
