It's on the right rear lower control arm about 1/2 way between the diff and the wheel.
A little box with a lever sticking out connected to some small linkage.
To remove the rear spring you have to disconnect the shock and then put your foot on the brake caliper and push the suspension down.
It's debatable that the level sensor has enough travel to allow it to extend that far.
Disconnecting the linkage is a bit fiddly, but it beats breaking it.
