The SRF is 590 dry / 518 wet , and is designed for prolonged use, I.e designed not to absorb water . Brake fluid absorbs moisture over time so Motul 600 for instance is no where near a 600 degree boiling point after a month( it's 410) it's also only 593 dry ( false advertising lol) . I would rather pay more and know my fluid is good for a year. If you don't mind replacing the fluid frequently then it's fine to use other things. Super blue is good , but the pedal feel is much more consistent with SRF than Motul 600 and super blue after a couple months . I've used all three .
