I've finally changed to a square setup and it's very close to the front part of the wheel liner; about 2mm clearance. But it's rubbing at the light bulb access cover on both sides. Anyone has a similar situation? If so how do you solve it?
265/35-18 Falken 615k+
18x9.5 ET35 with 5mm spacer
2.5° camber and zero toe.
camber bolt installed..
thanks,
