      05-23-2018, 09:22 AM   #4
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Originally Posted by chickdr View Post
Not sure what you mean. It certainly is an angel eye(or "halo"), just an early version before they started doing them in LED. Angel eyes are DRL's on most BMW's (base model 3 series use a more basic scheme without the halo).
To answer the OP- I would suggest you take a run at it yourself (see link below for details). There are two options. BMW sells the bulb already in its holder which is a bit pricey(~$40). You can also buy a bulb online for a couple of dollars and modify your existing holder to make the bulb removable. A dealer is going to charge around 30min to do the job if you don't want to.
http://www.zpost.com/forums/showthread.php?t=949497
Technically you can call that angel eye/DRL. It is so dim you can't really see it compare to other models. I didn't know they switched to LED on E85/86.
